Shaking
I have a 2009 Chevy Express 2500. The van will shake when using the brake between 40 and 60 mph, fine at all other speeds. So far I have had new tie rod ends(innner and outer), 4 new rotors, all new brakes, new rear calipers, new shocks, new sway bar ends, new idler arm assembly, new tires (balanced and aligned) I don't feel it in the peddle, it's far worse downhill or pulling a load. Every mechanic just tells me new rotors. I have a hard time believing the old ones I pullled off have the exact same defect as the replacements immediately after replacing them, especially at only between 40 and 60 mph. If you have any suggestions I am open.
