Sliding Outside Door Handle
My 2011 outside sliding door handle is not right. The top pivot arm seems like its disconnect or broke. I can still open the door but not sure for how long. The top part of the handle is leaning out more compared to the bottom half of the handle when I open the door. Does anyone have any experience with this?
Thanks.
Thanks.
My 09 barn door handle did the same thing. Took the panel off inside removed the handle and found that it was broken. They are cheap but since I had it apart I just J-B Welded it back together plus it reinforced everything. I know the new ones going to do the same thing. Fixed it 4 years ago it's still holding up strong.
Of course its winter and cold and no heat to work in so I was wondering how much was involved in a replacement. This handle rarely is used and still gave out. Sheese...
