Speedometer Drops to Zero
Hey guys i need a little help with my 2008 Chevy Express, while driving on the
HWY i noticed the speedometer dropped to zero, also the transmission went to first gear and did not accelerate out of that until i pulled over and turn off ignition and restarted it. restarting the car is a temp. fix. does anyone have any suggestions on what it could be
What did you use to check for codes? Dash light is not a reliable indicator. I would suggest a trip to a tranny only shop and have them road test it....and use their shop machine to check the odb2......It sounds electrical. If it was mechanical then restarting the engine would not fix anything......
We apologize for the difficulties you're currently having with the transmission in your 2008 Express. Have you made your servicing dealership aware of this issue? We'd be more than happy to facilitate this process on your behalf and work toward a possible solution. If you're interested, feel free to send your VIN, mileage, contact information, and preferred dealership in a private message.
We look forward to your message!
Jasmine F
Chevrolet Customer Care
Hello acare86,
Jasmine F
Jasmine F
Hope the original poster sees this and gets the problem taken care of! I'll post a link in another thread where poster had same issue. GM needs to "reach out" to that person as well given that their issue started after having the dealership service the vehicle.
So Jasmine... What about all of us with failed intake gaskets or oem paint that peels off in sheets? (Tumbleweeds and cricket sounds begin now.)
<script type="text/javascript">window.onbeforeunload = function() {}</script><script type="text/javascript">window.onbeforeunload = function() {}</script><script type="text/javascript">window.onbeforeunload = function() {}</script><script type="text/javascript">window.onbeforeunload = function() {}</script>
We evaluate each customer concern on a case by case basis. However, if you have encountered issues with the intake gasket or paint we're more than happy to investigate this matter as well. If you'd like to send us more specific details about your vehicle and situation we're available via private message to discuss.
Thanks,
Amber N.
Hello acare86,
Jasmine F
Jasmine F
