Starting an 05 6.0 on a 3500 without the cab
Old Apr 22, 2023 | 8:34 PM
Tundrawolf's Avatar
Banned
Default Starting an 05 6.0 on a 3500 without the cab
Hi,
I am building and extended frame custom 4x4 van, and have the engine, transmission, and transfer case mounted with the cab off, and am about to fabricate the drive shaft to make a complete rolling chassis.
I want to start the engine on the frame, but without putting the cab on.
I have an 03 1500 with 5.3 (Same as 6.0) I borrowed the engine harness from, but right now I am interested in getting the instrument cluster working, and the ignition system. I do not care about anything else other than the engine running, and instruments.
My idea is, to cut the harness in the 03, to the fuse box, to the ignition, to the cluster, and basically cut everything else. (Heater, doors, lights, airbags, radio, etc.) Just to get the engine running to make sure it will start before I put the cab on. If it starts and runs and makes good oil pressure, I will shut it down, toss the donor harness, and put the cab on after painting the underside and buttoning it up, basically making a running, driving cab that needs the *** end fabricated to it.
Are there any ancillary components on the cab harness required to make the engine run? I doubt it, but that is why I am asking.
Thanks.
Old Apr 23, 2023 | 12:34 AM
Tundrawolf's Avatar
Banned
If I ran a jumper to the fuel pump and ECM1 and blipped the starter I wonder if it would start.
BlackTurtle
Jul 21, 2021 3:24 PM
David G. Foley
Jan 18, 2016 10:03 PM
fastvold
Nov 21, 2014 1:27 AM
mikewaterskis
Jan 31, 2007 1:12 PM
