Van -Rear door lock problem
Express 1500 Van -Help w/Rear door lock problem
On my 2000 conversion van (1500 Express-Gladiator Package) I have the following problem:
The left side rear door, while facing the back of the van, has a problem with the door release. The right door opens normally, which then gives you access to the door release of the left side door(located on side edge of the left door). This door release feels as if it is swinging free inside the door. I removed a recessed tire inflator and housing from the left inside door panel to get a look inside. the upper and lower rods connect to a plate and there is a spring that has fallen loose. This plate is also no longer attached to the release lever. Do you have a diagram of this mechanism intact and what is the best way to gain more access and to put it all back together. Should I take that entire inside door panel off and if so when the trim is removed do you just pry it off? Thanks
1998 Express van - Gladiator
I have the same exact issue with my van:
My 1998 conversion van (1500 Express-Gladiator) running into following problem:
LeeHamilton
October 26th, 2014 9:49 PM
davbell22602
March 10th, 2010 8:36 PM
