03 4.3L no oil from pushrods?
Someone told me I might have a spun cam bearing/bushing?
I need help understanding the path of the oil psi feed system!
The gauge shows oil psi and only some of the lifters are making noise. At idle a few push rods are sloppy loose. None of them were squirting oil when I checked them. That is how far I have gotten in the troubleshooting and now I am stuck.
Do I have to pull the cam and look for the oil passages to be blocked? I was going to swap lifters out of another motor. I had planned on checking the cam lobes and surfaces.
The motor is in an Astro van and I want to repair it in place. Thanks in advance
Big D
January 10th, 2008 6:53 PM
larry_chip
April 24th, 2007 11:46 AM
