03 impala 40,000mile misfire problem(replace plugs n wires n checked coil)
#11
Professional Mechanic
If the cylinder was washed out by fuel it could have 0 compression. Did the guy add some oil to the cylinder and re check? If the car sat for a year it is possible that caused rust in the cylinder or on the valve causing the problem. Did the guy do a cylinder leak down test to pinpoint why it has no compression? It could be a rocker arm orpush rod problem. It would be extremly odd for that engine to be shot. You may want to take it to someone else for further diag.
#12
That was the local shop I use for normal issues like check engine light n inspection. Plus the owner is a friend of the family. They usually tell me whats wrong and i fix whatever it is. I'm going to take it to a Chevy dealer and have it investigated further. I'm hoping the problem is fixable. Should I be ok driving it to the shop about 5 miles away or should I have it towed?
#14
I need help to solve this mystery.
Okay guys, I have cylinder 6 misfire. sometimes i go 2-4 days without the light coming on. Everytime it does, I take it to autozone to get the codes and it says the same thing cylinder 6 misfire. most of the time it runs fine but when i does misfire i'm usually stopped and fixing to give it gas. I got my mechanic put new plug wires and new ac delo plugs in it and a new ignition coil on it( well actually two cuz the first one i bought had a crack in it). I've had my mechanic check my air pressure, and for vaccum leaks. I CAN'T FIGURE OUT WHAT IT IS...cuz it doesn't do it all the time. any ideas...
Btw I drive a 99 Chevy Mailbu 6 cylinder
#15
I had the same problem with my impala misfire on #3 changed the coil 2 times and still would misfire in short amount of time . I changed the control module located under the coils problem solved . I went the cheap route and bought a used one from salvage yard .I think it was about 50.00 and it came with the coils also . Mine is a 3.8 engine I am not sure your set up is the same now that I think about it .
tbb2
October 26th, 2012 5:28 PM
buijon
June 5th, 2008 9:30 AM
cregmonroe
March 26th, 2008 6:19 PM
drewsm3
July 26th, 2006 9:22 PM
