1955 3100
I have a 1955 3100 that is 98% original was given to me by step father when he passed. i have checked the numbers and heads intake and block all match the truck. Here is my question i need to rebuild the motor but truck was down for over 18 months on the body work so i have not droven it much. I am wanting to put a used motor in while i rebuild this one at what year did they stop putting the holes in front of block for the motor mounts. I am not interested in buying the adaptor for a newer motor i just want to have a truck to cruise until i can get the original motor back in thanks
I'm having to guess is it a 283? Since it is a one ton, would have to be a v-8, but not a 409 as those came out in 1961.
no this is the 2nd edittion of 1955 with the original 265 v8 and i posted int his section cuase i will take any small block chevymotor i just want the mounting bolts in front thanks
You can get good mounting bolts at <cite>boltdepot. They have a pretty good collection of it. Your truck engine was down for 18 months, that's a huge time, you should really check if the motors still function as they should.
</cite> |
have 1961 gmc 1ton flat bed has a v6 https://www.facebook.com/images/emoj...1/16/1f641.png:( it turns over but wont get spark put coil,plugs,distributor cap,plug wires any ideas whats wrong checked connections on coil
