Old Nov 12, 2012 | 1:02 PM
timinaz's Avatar
Default 1955 3100
I have a 1955 3100 that is 98% original was given to me by step father when he passed. i have checked the numbers and heads intake and block all match the truck. Here is my question i need to rebuild the motor but truck was down for over 18 months on the body work so i have not droven it much. I am wanting to put a used motor in while i rebuild this one at what year did they stop putting the holes in front of block for the motor mounts. I am not interested in buying the adaptor for a newer motor i just want to have a truck to cruise until i can get the original motor back in thanks
Old Nov 12, 2012 | 4:33 PM
kevinkpk's Avatar
I'm having to guess is it a 283? Since it is a one ton, would have to be a v-8, but not a 409 as those came out in 1961.
Old Nov 12, 2012 | 5:40 PM
timinaz's Avatar
no this is the 2nd edittion of 1955 with the original 265 v8 and i posted int his section cuase i will take any small block chevymotor i just want the mounting bolts in front thanks
Old Nov 17, 2012 | 2:39 AM
rafaelsmall94's Avatar
You can get good mounting bolts at <cite>boltdepot. They have a pretty good collection of it. Your truck engine was down for 18 months, that's a huge time, you should really check if the motors still function as they should.
</cite>
Old Sep 21, 2017 | 5:33 PM
Cooper Rankin's Avatar
have 1961 gmc 1ton flat bed has a v6 it turns over but wont get spark put coil,plugs,distributor cap,plug wires any ideas whats wrong checked connections on coil
dtachia
Apr 23, 2011 1:51 AM
shawnmid
Jun 1, 2010 8:49 PM
paul_houle
Apr 6, 2010 11:18 PM
69z28
Dec 15, 2008 5:56 AM
cartitles
Sep 10, 2008 10:40 AM
