1989 Celebrity 2.5L water pump removal?
Old December 17th, 2008 | 5:37 PM
BillNCarol's Avatar
Default 1989 Celebrity 2.5L water pump removal?
In the process of removing the water pump removed what i thought were all the bolts but it won't come off. it pivots side ways left and right, I put my finger on the bottom of the water pump and i feel a bolt that it may be pivoting on but it is impossible to get a wrench to for the pulley is in the way. Over the years ive changed water pumps with bolt on pulleys, im not familiar with a press on type of water pump pulley I would like to know if that is indeed the case. It is the same type of pulley as the tensioner pulley in which i removed by removing the bolt. But this pulley does not have a nut , it has a round ****. Any help would be greatly appreciated. And if so would a normal three prong wheel puller do the job. Thanks
brit
June 29th, 2014 9:56 AM
Greywolf
May 12th, 2011 3:12 PM
BillNCarol
April 12th, 2010 3:01 PM
richardbentz
July 21st, 2006 8:46 PM
kc8zdf
July 1st, 2006 3:10 AM
Quick Reply: 1989 Celebrity 2.5L water pump removal?
