1991 suburban starting problem
Old Feb 22, 2009 | 10:06 AM
greasy1025's Avatar
Angry 1991 suburban starting problem
well i have a 91 suburban just put in a 93 tbi 350 and 4l60e. the problem is it starts and then stops if i hold the gas in a little bit it will stay running if i let off it dies. any help would be great I also put in wiring and fuel pump out of 93 that did run perfect
Old Feb 23, 2009 | 2:31 AM
irdaneel's Avatar
If it is fuel injected, check your idle air control valve. If it doesn't open, it can't idle.
If it is carbureted, check there.
Old Feb 23, 2009 | 3:35 PM
greasy1025's Avatar
will have to have a look every thing worked fine in the other burban i pulled motor and tranny as one unit and all wiring
Old Feb 23, 2009 | 4:58 PM
greasy1025's Avatar
put in new fuel pump and filter still no luck i about done anybody want to buy a 91 4x4 with 93 motor and tranny
Old May 1, 2011 | 10:47 AM
MudBoggerBurban's Avatar
is the timing right?
FLV8Jeeper
Jan 23, 2022 12:16 PM
KLamp91
Feb 7, 2014 10:41 AM
bobnance
Jun 3, 2009 9:17 PM
Roman931
May 18, 2006 1:51 AM
