1992 silverado fuel pump problem...
Old Apr 16, 2009 | 5:50 PM
wastedyouth's Avatar
Default 1992 silverado fuel pump problem...
i have a 1992 k1500 4x4 zr2 off road with a 5.7
i parked it at work and when i went to leave it would just turn over and not start.
i noticed i couldn't hear the fuel pump, so i put a new fuel pump relay in, then a new fuel pump.
then i checked for spark and im not getting spark.
so i replaced the ignition module thats in the distributer cap.
still no spark or fuel pump...
im stumped....
Old Apr 17, 2009 | 12:02 AM
Mike Sigmond's Avatar
ROTM Coordinator
Have you checked your fuses & relays? sounds like a loose wire,fuse or computer problem.
Old Apr 17, 2009 | 8:09 AM
therewolf's Avatar
Have a look at your CPS.(Crank Position Sensor)
Old Apr 17, 2009 | 8:50 AM
make sure the cable from the coil is good....
Old Apr 17, 2009 | 6:24 PM
all the fuses and relays are good.
monday in going to use a computer and check and run some codes and see what that has to say.
but for now i'll keep you posted on it.
Old Apr 23, 2009 | 8:44 AM
Koffietje's Avatar
Can you measure the voltage on your fuelpump , coming from the battery? (I know its kind of almost impossible to get to it ) . There should be some wires going in there. If you dont get any reading there, then well...its fuses or relais or ...
Old Jan 6, 2013 | 5:05 PM
William E Cullins's Avatar
i ran a hot wire to pump will run now but will not run off relay
mangomanj
Aug 17, 2014 9:51 PM
BRB
Dec 28, 2012 8:34 PM
hunter10220
May 18, 2011 8:37 PM
SuperTexan
Oct 23, 2008 1:00 AM
