2005 Silverad 2500hd
Need helps guys. My truck after driving it to work and parking it for 8hrs dies. When you try to start it nothing happens no click or nothing. But if u come and start it the next day it starts fine. Happened a couple of times already. Twice the chevy dealer couldn't find out what was wrong with it. Need help. email me at lorkue@hotmail.com
First, have your battery checked, you probably need a new one. The OEM batteries are side-mount,(HAR-UMMPH!!{kiss of death}) and, like everything else on the truck, are only designed to outlast your warranty.
There was a battery discharge issue involving the vehicle's computer, but that would discharge the battery every time. Check your cables. I changed all three of mine in my 04 2500HD last year as cheap insurance. There's a chance they may be starting to corrode. When my battery went last year, I chose an Optima Red Top gel-cel- more because Advance Auto Parts has a branch close to many places I drive, in case of a return issue. Interstate makes a killer battery for the money, but the dealers are harder to find, mostly garages. But Sears Die Hard is manufactured in the same factory as Interstate, and they're famous in their own right. |
Originally Posted by rivereye
(Post 116667)
There was a battery discharge issue involving the vehicle's computer, but that would discharge the battery every time. Check your cables. I changed all three of mine in my 04 2500HD last year as cheap insurance. There's a chance they may be starting to corrode. When my battery went last year, I chose an Optima Red Top gel-cel- more because Advance Auto Parts has a branch close to many places I drive, in case of a return issue. Interstate makes a killer battery for the money, but the dealers are harder to find, mostly garages. But Sears Die Hard is manufactured in the same factory as Interstate, and they're famous in their own right. I've changed all my cables. The battery i'm running is a interstate. But for some reason it still does it? |
Sounds like it might be the computer issue then. Did you remember to change the engine/body ground strap?
Also there may be a small short draining your battery.With your ignition off, disconnect the positive cable. Attach a test light between your positive side of your battery, and your positive cable. Is the light lit? If it is, start pulling and replacing your fuses one by one. When your test light goes out, you found the circuit with the short which is draining your battery. Don't forget there's two fuse stations on your vehicle, under the hood, and by the driver side door. |
| All times are GMT -5. The time now is 10:14 AM. |
