66ChevyC10 |
October 29th, 2018 11:43 PM |
350 SBC Vortec Not Starting. Possible Tuning Issue
Hello, I'm new to the hot rodding game so I'm learning things as I go and I finally came across a problem that has me stuck. My issue is my 350 sbc vortec with an Edelbrock 1406 carburetor isn't starting. I am getting spark and I can smell the fuel so I'm guessing the issue may be a carb tuning issue. I started give the carb primary and secondary a full turn at a time and it sounded like it wanted to start and had the initial rumble but just wouldn't start. My C10 was starting to die at idle and completely didn't want to start after I installed a new water pump. Since then I had my carb rebuilt and installed a new HEI distributor. I went through all the steps to set initial timing and I checked I'm getting spark and fuel. Within a couple of months of running into this issue I installed a new battery, CD Ignition, starter and alternator. The starter is engaging when I attempt to start the car and I have a charger connected so I don't kill the battery. I wasn't sure what the carb shop set my tune to so I reset everything to closed and I'm starting over with giving the primary and secondary a 2 and a half counterclockwise turns and the idle 3 counterclockwise turns. I then through in 3 seconds of starter fluid and attempted to start the engine without any luck. Any suggestions?
