4l80e no reverse
Old Oct 26, 2019 | 9:43 PM
Russ Chamberlain's Avatar
Default 4l80e no reverse
The cooler busted; drove the van 5 miles.
I received over heat, Tworkconverter locked no, trans slip codes.
I pulled the pan, and valve body, checked the drums and exposed clutches, all looked good; I cleaned and inspected all valves, I Replase the A solenoid (the plastic was busted.
I did not clean the reverse acclimator...
I added new fluid let it idle, dropped the pan no debre
I gave it new fluid. No reverse; 1,2,3,D all engage.
I pulled the main trans plug still no reverse.
It was lunging Fowerd in reverse when first tried R.
It has a new rebuild from 2017 with less than 2,000 miles. What is the issue?
EJM
Nov 22, 2018 7:23 PM
10267412
Jul 26, 2014 11:43 AM
10267412
Jul 25, 2014 9:13 PM
Cjkingnsc
Jul 12, 2014 1:14 PM
Kev
Jul 9, 2006 12:23 AM
