98 Chev 1500 signal lights
Hey on my 98 Chev 1500 my signal lights aren't working like there suppose to... I hit the switch to make my turn and then it will turn the light on but will not flash..I need to manually.. I changed the relay for them and still the same thing. Does anyone have any ideal what could be wrong with it?
Hopefully this makes sense
Thanks in advance
Thanks in advance
You haven't done quite enough checking...
Check (ohms) each lamp (4) for continuity on both elements.
Should be "0" ohms
Check (ohms) continuity from the socket (4) cases to ground.
Should be "0" ohms
Turn your turn signals on (L then R) and verify voltage at each (F & R)socket.
Should be pulsing over 12vdc
Do your Emergency Flashers (all 4 corners) work ?
At what rate (pulses per minute) is your Flasher operating at ?
Should be "0" ohms
Should be "0" ohms
fishingpro77
HHR
August 4th, 2016 12:44 AM
Hectorson3
September 13th, 2014 12:22 PM
RomanGuzi
October 2nd, 2011 11:40 AM
bentwrench
August 25th, 2011 5:52 PM
Brandonion1985
July 16th, 2011 7:17 PM
