99 Tahoe with 5.7l won’t stay running while in gear
Hey all. I have a 99 tahoe with the 5.7l motor. Just replaced fuel pump and filter. It will start after cycling the key a few times. It will rev in park and neutral as high as I can get it. If I put it in gear and give it gas it will run, and idle. If I try to just roll in forward or reverse it dies and I need to cycle key a few times to get it running again. The fuel pressure at the rail was about 40 psi before I changed the pump and filter. Have not tested since change. Anyone ever deal with this issue? Any thoughts are much appreciated.
