Air Condition issues
I have a 2001 Chevy Suburban that is blowing out hot air. I have change the intake valves because it was leaking put three cans of Freon and it blew out cold air for one day and the next day it was back to hot air. Took it to firestones to get a Air condition system check and they told me the compresser was working great. Don't know what other steps to take to make the air condition work...it's close to 100° here in Texas and I'm having great concerns driving my kids in the truck. Any help or suggestion is greatly appreciated.
the only valves in an a/c system are reed valves in the compressor. Not sure what you are referring to there?
+1 for the large leak. get the leak fixed and you will be golden.
Our ac is blowing out defrost only mode, seems theres a couple actuators, one controls the temp of the air, the other controls the place it comes out and of course blower motor, I would start there. I think they are mode actuator and blend actuator, one for temp is on pass side and one for mode is under dash near gas pedal. If you've recently disconnected the battery, there is also a trick you can try with the key, youtube it, hope that helps.
