Carburator
Old Feb 8, 2019 | 10:07 PM
Smokin' Smitty's Avatar
Default Carburator
What size holley for 350?
Last edited by Smokin' Smitty; Feb 8, 2019 at 11:06 PM. Reason: Change weber to holley
Old Feb 9, 2019 | 7:25 AM
oilcanhenry's Avatar
Depends all on the vehicle and what you intend for it, If its been modified (headers, intake manifold, compression ratio, cam and so forth) you could use a 650-750 to 850 CFM , if you've modified it like that
Likely a 600-650 CFM would work fine. If its pretty stock then a 450-500-600 CFM Holley should work fine, Have to make sure that you have the kick-down style if you have an automatic. The Holley 4160 is nice and you can find one that will meet FED and CA emissions regulations too.
