Chevy 350 distributors
Have a distributor that don't have a nipple on the advance timing. Can I convert current distributor to use the vacuum port or do I need different distributor with vacuum port?
You'll need to make sure the vacuum diaphragm isn't leaking, as they do wear out. That's simple, as if you suck on the vacuum port, it shouldn't allow you to have any air coming through. Changing out the vacuum advance diaphragm is cheap and easy to do, however.
