Governor?
is it possible to remove the governor with out throwing the motor out of whack ?? my truck has wayy too much power to only stop at 100....
Thanks!!:D 1998 chevy 2500 3/4 ton 5.7L single cab |
Many tuner chips can remove the speed limiter, the limiter is there to prevent you from out running your tires... if your tires are not for high speeds ( most truck tires are not) your tires can come apart at those speeds and loss of control can occur....also trucks get much more air under them then a car and can become airborne or loose steering responsiveness...
could you recommend any chips i could get?
Hypertech is a common chip tuner for your year model...
check them out here http://www.hypertech-inc.com/products-results.aspx |
