Governor?
Old Mar 19, 2014 | 8:45 AM
ty.sikes's Avatar
Default Governor?
is it possible to remove the governor with out throwing the motor out of whack ?? my truck has wayy too much power to only stop at 100....
Thanks!!
1998 chevy 2500
3/4 ton
5.7L
single cab
Old Mar 19, 2014 | 11:30 AM
Many tuner chips can remove the speed limiter, the limiter is there to prevent you from out running your tires... if your tires are not for high speeds ( most truck tires are not) your tires can come apart at those speeds and loss of control can occur....also trucks get much more air under them then a car and can become airborne or loose steering responsiveness...
Old Mar 19, 2014 | 12:25 PM
ty.sikes's Avatar
could you recommend any chips i could get?
Old Mar 19, 2014 | 12:53 PM
Hypertech is a common chip tuner for your year model...
check them out here http://www.hypertech-inc.com/products-results.aspx
radii
Apr 13, 2007 11:28 AM
Drock77
Feb 12, 2007 4:25 PM
colbaltGUY
Cobalt
Oct 31, 2006 12:22 AM
whytespyder
Jun 12, 2006 1:19 PM
95FROSTY
May 24, 2006 12:28 PM
