Notices
heat risers and center of heads smoking hot
Old February 2nd, 2010, 1:08 PM
jacob brooks's Avatar
Default heat risers and center of heads smoking hot
I have a early 350 casting num# 3970010 1969-80 with heads cast# 33388-2 1974-80 76cc, Here is the problem, The center of my heads and intake manifold get hot enough to burn paint, burn oil, and discolor the head, push rods and intake. I dont have resticters or block offs in the riser port yet, I was concerned of doing that thinking it might make it worse on the heads. I don't have a over heating problem at all as far as temp of the entire system. Just the center of the head and intake. the initial timing is 8 and overall is 25. I have pulled the heads had them magnafluxed and surfaced. This engine is in my boat and the boat forum told me to try a chevy forum so here I am. I have built many motors and have what I considerd alot of knoledge of these motors, but I have never seen this it does not add up. The only thing I can think of is that the exhaust valves are not closing all the way of the cam is bad ? the motor runs perfect. please help Im lost!!! thankyou
Old February 2nd, 2010, 1:31 PM
Ride of the Month
May 2009
mudmaniac's Avatar
Do a compression test to confirm your thought on the exhaust valves.
Old February 2nd, 2010, 2:08 PM
yea thats true I did already and it was 145 across the board. So I guess that rules that out. any other thoughts? thanks
Old February 2nd, 2010, 4:14 PM
Ride of the Month
May 2009
mudmaniac's Avatar
It could still be an issue with the cam lobes wearing and changing the duration.
Old February 2nd, 2010, 4:33 PM
is there a way to determine that with out pulling the cam? I bought this boat with the motor in it and it was newer? who knows but I know the lifters looked good!
Old February 2nd, 2010, 4:55 PM
Ride of the Month
May 2009
mudmaniac's Avatar
You could pull the valve covers and measure the lift.
Old February 2nd, 2010, 7:15 PM
ok thanks
Old February 2nd, 2010, 7:46 PM
cam3439's Avatar
Did you ever find out your problem?
Old February 2nd, 2010, 9:36 PM
no, but I think it might be my fuel pump starving my motor of fuel at higher rpms causing it to run lean. thats what im trying now, I have an electric fuel pump that is only rated for 2.5-3 gpm and a holley typically needs 4gpm and Im pushing through a fuel block water sep. Ill let ya know if it works
Old February 2nd, 2010, 9:54 PM
old dog's Avatar
Default hot stuff !
those port's are there for a reason on automotive and truck use they send exhaust heat under they intake to warm the fuel for better warm up when it is cold out .every small block with out the port's blocked off will cook all the oil and paint on them in that area .it,s the way they are designed for car's and truck's .you probably don't need them in a boat because you don't run it when it is cold and freezing out . put some aluminum or performance heads that the boat builder,s like .or dont worry about them .
Quick Reply: heat risers and center of heads smoking hot
