I need some advice please
Hi everyone so my chevy has some visual issues. It has some rust on it. It is an older model, however I was wondering if i could take some of that rust off. I looked up how to take off rust online and I found this site{SITE DELETED BY MODERATOR} does anyone know if this stuff is safe and if it works as good as it says it does? Thank you.
Advertisers LIE.
I have never seen a Before/After
picture comparison which wasn't
total fabrication.
IF you want to remove rust, try what everybody else
has been using dependably for centuries:
Vinegar(soak)
wire brush and elbow grease(apply vigorously)
thick oil or light grease(apply sparingly)
Now, please edit this advertiser's link from your
post...
total fabrication.
Vinegar(soak)
post...
Is your vinegar method safe on the body surface? I did end up buying the stuff from the post, i bought a concentrated gel form, i will try and post pics of before and after.
Isolate the area with newspaper and masking tape. Feather a surface area
around the rust area at least 3/4", being sure the area around the rust is
bare metal. Then sparingly apply vinegar to the rust only with an
applicator, a q-tip,etc. Dry. Wash. Carefully sand to bare metal, and prime.
Finishing techniques I leave to the Body Shop guys.
jvelasco23
Uplander
16
October 29th, 2013 8:21 PM
cleancutbusinesses
November 4th, 2012 7:37 AM
vimagine
April 16th, 2007 7:00 PM
cjb
July 29th, 2006 4:00 PM
