Low to no oil pressure on a small block 350
#11
My '98 Z71 is having some problems with the oil as well if anyone can help point me in the right dirrection to get this fixxed. when driving my psi is fine and then when I come to a complete or near complete stop then resume to accelerate my oil pressure drops down to zero, it returns to normal after hitting higher RPM's but could this be a pump or a gauge?
![Smile](https://chevroletforum.com/forum/images/smilies/smile.gif)
david g.
#12
Well I have a 1974 350 engine and I had a mechanic change my intake but he said the intake that I got for it would not work so I had him to put it back together and but I never seen him drain the fluid out of intake or engine could that be my problem on low oil pressure. When I first start it the oil pressure is about 40 percent and after about 20 minutes it's down to 5 % to none need help
#13
if the oil pressure was OK before you might have some old gasket or sludge that was dislodged when pulled the intake sucked up into the oil pump pickup .you might have to pull the oil pan to be sure .
BoogerHog
December 25th, 2016 11:32 PM
viborero23
December 5th, 2009 8:03 PM
Bookscout
June 11th, 2008 6:38 AM
