mild 454 timing
Old May 22nd, 2015 | 1:22 PM
m.sayles13's Avatar
Default mild 454 timing
Hey guys just wondering if I could get some opinions.
Just built a 454 bored .030 over with a 268 cam, 9.5:1 compression, and a hei distributor. I've been playing wigh the timing and have found it seems best at 20° base timing and 42° total with the vacuum advance unhooked.
It doesn't have any sighns of detonation on the plugs and I can't hear anything that sounds like detonation either.
I followed a build that was in hot rod magazine that is very close to mine and it said there total advance was 40° so I'm thinking 42° is probably fine, As long as there's no harm being done .
Anybody ever hear of timing being set this high?
Old May 23rd, 2015 | 11:35 AM
J.W. Racing's Avatar
If there's no knock, go for it. I run mine at 42 degrees, but I run higher octane fuel. Also play with the springs on the weights on your distributor. I usually run a soft spring on one side and a medium spring on the other.
oldslowchevy
February 22nd, 2013 8:18 AM
heavychevy511
October 31st, 2012 9:43 PM
akchev
July 12th, 2011 8:28 AM
woodstockaz
August 15th, 2010 5:08 PM
Quick Reply: mild 454 timing
