My AC Control keeps resetting
Old Nov 5, 2020 | 6:03 PM
arnel jalbuena's Avatar
Question My AC Control keeps resetting
I replaced one of my broken actuators because my AC only blew air to the defrost and heat vents. I messed up my AC Control module and bought a new unit and replaced it. I reset the system following the procedure i found online. It worked but sometimes it reverts back to just blowing air to the defrost and heat vents then i have to reset the system again. This usually happens if I change the direction of the air flow. Can someone help me figure this out? Thanks in advance.
Old Nov 5, 2020 | 8:43 PM
oilcanhenry's Avatar
Mt guess that your climate control unit is defective, so it reverts back to its original programming.
Old Nov 5, 2020 | 9:16 PM
chevyboy@22's Avatar
First, my advice is take it in to the dealer.
But if you need to work in it yourself, you'll need a set of AC gauges to know what's going on with the AC. Again, my advice is take it to the dealer.
Old Apr 17, 2025 | 2:30 PM
lvmcpa's Avatar
Default Any Luck
I know this is an old thread but I am having the exact same problem. Any luck?
QUOTE=arnel jalbuena;455670]I replaced one of my broken actuators because my AC only blew air to the defrost and heat vents. I messed up my AC Control module and bought a new unit and replaced it. I reset the system following the procedure i found online. It worked but sometimes it reverts back to just blowing air to the defrost and heat vents then i have to reset the system again. This usually happens if I change the direction of the air flow. Can someone help me figure this out? Thanks in advance.[/QUOTE]
Agates21
2007 - 2013 (GMT900)
Sep 29, 2025 7:15 AM
Jorge Solis
Jun 29, 2019 3:19 AM
dhawthorne15
Sep 28, 2014 1:41 PM
ambmech
Aug 17, 2011 10:26 AM
kels2kara
Jul 18, 2010 4:37 PM
