No Idea Where To Start
2 Attachment(s)
So iv started to work on a project thats been sitting for some years. My dad built the motor and truck probably about 10 years ago and doesn't remember a whole lot about what he had to do when he put it all together.. Im going to be swapping a 502 out of a 1996 K3500 into a 61 C10 pickup. I am lead to believe the motor is a Gen 5 454, punched out to a 502. It has a whipple supercharger kit on it as well and a built trans. Some of my questions are as follows and if you have any info please share!
Ill have more questions as i progress but for now this is all i have, im mainly just concerned with all the wiring and keeping the motor happy in the 61 as id like to use everything i have and not have to buy a carb set up or something of that nature while at the same time the only electronics i want it to have are just to run the motor. Attachment 10349 Attachment 10350 |
Yes the casting number on the rear of the block behind the cylinder heads will help determine the block you have.
Chevy Casting Number identification - Block casting numbers https://en.wikipedia.org/wiki/Chevrolet_C/K#C3500_HD The 96 K3500 came with two different engines the 5.7/350 and the 7.4L/454, since you have the 454 made in 96 you could have the L29 which was an option. https://en.wikipedia.org/wiki/Chevro...ock_engine#454 You will need to remove the ECM, and all the wiring for the engine, the harness will be separate from the rest of the electrical wiring harness. Also ensure that if the truck used electric fans that they are included in addition to the harness for the fans. There are different aftermarket systems you can get to manage the engine, MSD, Holley, and Eldelbrock would be a good starting place to start. In addition to you will need to have the system tuned to compensate for the addition of the blower. Looks like you have a major build on your hands. Have fun |
