No reverse lights or back up camera working
Old Nov 17, 2025 | 8:48 PM
Therealcrt's Avatar
Default No reverse lights or back up camera working
I’ve checked all fuses replaced bulbs in back up lights nothing works. Idk why the reverse camera isn’t working either someone help?
Old Nov 17, 2025 | 11:22 PM
Rednucleus's Avatar
Welcome to Chevy - please post your vehicle details
Old Nov 24, 2025 | 8:33 AM
Hulk40187's Avatar
to start a thread, you need to add year, make and model
Old Nov 24, 2025 | 8:39 AM
Therealcrt's Avatar
2014 Chevy silver 1500
Old Nov 24, 2025 | 9:02 AM
Hulk40187's Avatar
I would start by double checking fuses again, i believe it’s fuse 33 for that, i know you already checked but just to be sure, the next place to check is your range selector switch or safety neutral switch some call it, this tells the computer which gear you are P,D,R ect. The contacts for reverse lighting are integrated into the switch, check the harness, unplug the harness look for corrosion, dirt, clean if necessary, plug it back in, see if that works, check the wiring also, aftrr that have a friend shift the vehicle (not running) safely go underneath and observe the switch while moving through gears, mainly into reverse from P and from D, look for anything that doesn’t seem normal, if you can’t find an issue, you may need to get a wiring diagram and chase wires for broken or chafed wires. Hope this helps! Have a good thanksgiving!
Old Nov 24, 2025 | 10:20 AM
Therealcrt's Avatar
Where is that switch or module located? And where do I look under the truck while someone is switching gears
Old Nov 24, 2025 | 12:53 PM
Hulk40187's Avatar
on the side of the transmission, driver side, my apologies for not giving you the location, you should see your shift lever cable attached to it.
Engelwood39
2014 - 2018 (GMT-K2)
Feb 7, 2026 11:05 AM
smbsvcs
16
Apr 21, 2022 10:17 AM
Anthony82
Avalanche
Dec 11, 2018 5:15 PM
rjg8486
Jun 5, 2014 2:56 PM
bigdd
Apr 11, 2011 5:58 PM
