No spark from coil 97 350 vortec
#11
No spark from coil
I changed computer , crank sensor , distributor and ignition module turns out the crank sensor was bad however the bolt holding it had stripped and was not allowing correct spacing for sensor. I used a 3/8 _16 bottom tap to rethread plastic housing to be able and tighten bolt that holds sensor. Problem solved. Good luck.
