No Start
No Start
03 Impala 3.8 eng. Ran fine shut it off tried to start about 1/2 hr no start. Let sit another 10 mn started. Drove home fine. Next morning no start let sit 10 min started, While trying to no hum from pump, after starting and shut off fuel at fuel rail. Changed pump started fine drove fine. Shut off let sit for 1 hour no start no hum from pump. Changed fuel pump relay. and all the same problems continue. Any ideas before she goes to the shop. Also, will the $100-150 scanner find a problem like this Thanks for any help out there.
I have a related issue with my 1999 Chevy Tahoe LT 5.7L V8. Always started fine, no hesitation just fired right up. Took it for a tune up, and all of a sudden she won't fire up. Put a new battery on and still will not crank, yet after 10 minutes it will. Took it back to the shop and they claimed the key is worn and tripping the security system causing it to disable for ten minutes. Claimed if it wasn't the key, it is a weak door lock actuator. Well new key and all five new actuators and the problem still persist. I think they screwed up on the tune up. I guess I will have to take it to a dealer, and get screwed further. Sorry, I know that doesn't help you any.
Thermool
June 20th, 2009 6:41 PM
wildboy74ss
April 1st, 2009 5:10 PM
izod
February 14th, 2009 2:42 PM
larry_chip
June 2nd, 2007 3:20 PM
