p0300 @#$#@#$%
A quick way to check for vacuum leaks is to get a can of carb cleaner and spray it around the base of the intake, throttle body and all the hoses. If there is a leak it will make the engine run different. Usually increased rpm's.
Have a tech with a scan tool check your CAM RETARD values. It's accessible from the OBD computer. If they're out of range (normal = +/-2 degrees), pull the distributor and check for a worn gear on the distributor. Another possiblity is timing chain slack or skipping causing erratic timing at the distributor.
TURBOPOWERED68
Jan 27, 2012 1:04 PM
advanceauto
Feb 27, 2010 9:51 AM
warrennaujalis
Oct 28, 2006 10:24 AM
