Please Help Me!
I spliced in a 4 prong wiring harness for a trailer...
Before Splicing: all lights worked After Slipicing: blew a fuse. all lights in rear of truck not working. brakes, turn signals, parking lights, not working...however, they worked, shut off, worked shut off, worked for 5 mins, then shut off for good After Replacing Fuse: brake and turn signals work no license plate and running lights Help please!! |
RE: Please Help Me!
remember the white wire is ground recheck your wiring for a short
RE: Please Help Me!
I did. If I undo the ground wire the brake lights and turn signals dont work. But when I reconnect the ground wire, they work, but the parking lights in the rear still dont work...
RE: Please Help Me!
ok dose the tail lights work when u unhook 4 way connector
RE: Please Help Me!
i cant unhook the 4 way because i spliced them in using those clips that you clamp down. in order for me to take it out, i have to cut out all the wires
remember... they worked, shut off, worked shut off, worked for 5 mins, then shut off for good |
RE: Please Help Me!
if its the clips that u place the wire in then fold cover over and squeeze to lock then all u have to do is unlock cover pull out the two metal things and it will come apart bot they are hard to reuse i would recommend soldering splices tape with electrical tape then coating good with silicone form a gasket or liquid tape that way u get a waterproof seal and won't have problems with corrosion on down the road but use rosin core solder
