Power window Issue
Old Jun 16, 2021 | 1:56 PM
cptmiker's Avatar
Default Power window Issue
Hello All I am hoping to get some good info here. Here is the issue I am having
2003 Chevy Geo tracker Power windows
I have the passenger rear drivers window not working properly.
1. window will roll down but not up
2. Checked the switch and has good continuity for both up and down modes.
3. switched with the rear drivers side switch that is working on the drivers side Same issue.
4. Tested power for both direction at the switch and the motor connector there is power flowing for both Directions.
5. tested the motor with a battery of both up and down and it works fine.
So I am very perplexed at this point Switch appears good motor works with direct power and has 12v for up or down at the switch. Could this be an issue with the main switch or is the motor just bad and need more power that the direct battery supplies.
Please help
Old Jan 11, 2024 | 10:20 AM
2brad's Avatar
Default Power window won’t go up
Please help
Did you resolve this? I am experiencing the same issue with a 2002 drivers side rear window.
Old Jan 11, 2024 | 5:59 PM
@2brad this is a pretty old thread and user is probably gone. You should post your own thread.
myinhousebigdog
Oct 27, 2024 10:39 PM
dbs600
Colorado
Mar 23, 2019 6:09 PM
