PROM Problem?
I hope you folks can help me.....I have a 2002 Malibu and it revs/surges/chuggles at
highway speeds by 200 to 500-rpm. It does it intermittently and enough to kick it out
of cruise-control, but not enough or long enough to "code". We have changed a whole
spectrum of things....four different shops....two were dealers. We changed out all of
the fuel-injectors, MAF sensor and a brake-switch. No go. Then, dealer flashed the
ECM/ECU. No go. Then, we changed out the torque-converter, torque-converter
clutch, pressure-control solenoid, hydraulic-valve, shaft and sleeve (per TSB). No
go. Next, we changed the throttle-position sensor and the ECM/ECU itself. No go.
I got opinions from two shops, one a dealer, one not. One sez to do more trannie
work like change-out the valve-body or replace the trannie in full. The other sez
it could be a glitch in the PROM for the ECM. It was NOT changed when the ECM
was. What does anyone think? Think it could be the PROM???????
Trannie has been worked on...torque-converter replaced, torque-converter
clutch replaced, pressure-control solenoid replaced, hydraulic-valve replaced,
shaft and sleeve replaced. No go. It still did the rev/surge/chuggle. One tech
sez it could be the PROM and another sez it could be the trannie's valve-body.
How does one check that? Oh, it generally does NOT do it under 60-degrees
ambient temperature outside.
We also did a trek to Atlanta GA from MN and it only did the rev/surge/chuggle
for the first hour of the twenty-hours of driving time. Same on the return-trip,
only an hour of the problem the whole of the route home......
weroll
Dec 27, 2007 11:11 AM
BSchorr
May 25, 2007 5:18 PM
