radiator question
It feels like ive asked this before but oh well. First its for an 03 eclipse, but its just the radiator. the plastic at the top has a hairline crack thru it, and leaks out about a gallon every two weeks, would J.B. weld or something of the like work for a temp patch?
I have repaired cracks in plastic before by heating up a flathead screwdriver red hot and fusing the crack back together. Just a thought. I am not sure it will work on the high temp plastic the radiators are made of tho, there is also pressure pushing on it when its operating too.
Plasma cutter first, I have a welding machine and access to many more, and will be googling this plastic welding machine you speak of. it'd just be cool to say i can weld plastic.
Hey Nauticstar87,
You can take that to a radiator shop and get a new top tank put on, for 30 or 40 bucks. I've repaired a few of these and I know, you don't want to be a tight wad when it comes to your radiator. If it overheats and wastes the motor then you'll want to kick yourself in the butt a few times for not fixing it right the first time.
As far as plastic welding a butane soldering iron works perfectly, use a zip tie like you would welding wire or rod. If you want to TEMPORARLY patch the rad I would use JB weld
