rapid flasher with LED
Newly installed LED signal lights flash fast and signal fail in message centre... is there a dif flash relay that can be purchased to fix this issue? thx
LED bulbs draw much less power than regular light bulbs. You can buy resistors on ebay that get wired into the circuit and bring the resistance back up to where it needs to be for proper flasher speed. You may be able to install a electronic style flasher that blinks at a set speed no matter what but newer vehicles may not be able to use this type of flasher. My one ton has double LED tail/signal lights on the rear and regular bulbs in the front and it blinks a fair bit faster than stock. I figure it just helps catch peoples eye better so I run it that way lol. Napa or ctc may have the resistors as well, they are little gold colored aluminum blocks with two wires.
Conradish006
July 7th, 2021 11:51 AM
Mdbragg96
July 13th, 2019 4:11 PM
