Rear View Mirror Wiring
I have a 2013 4WD Silverado with OnStar, HomeLink and Auto dimming mirror. I need to tap into the wires for ground and power (when the ignition is turned on) on the back of the rear view mirror for a Radar Detector. Can anyone tell me the correct wires to use?
2013-Chev-Silverado 3500HD
Interior & Driver Amenity
Electrochromic mirror
Which part are you having trouble with? There's no science to it.
The fork looking symbol is ground. It's on pin 8. Wire color is black ("BK"). Black is almost always ground.
"IGN" is power with the ignition on. It's on pin 13.It says "PK" which I presume is the pink wire.
The connector on the mirror should have small number printed on it denoting the pin numbers. Usually the numbering starts on the top left.
