Rekudo Suspension and Steering Parts on Sale Until March 31, 2025
Hey everyone,
If you're looking for better handling, braking, and overall performance for your ride, Rekudo has you covered. CARiD now represents this brand that is all about high-quality suspension, brake, and steering parts designed to make your car more responsive and fun to drive. Whether you're hitting the streets, the track, or just want a smoother ride, Rekudo parts are built for performance and reliability.
Their disc brake calipers deliver strong and consistent stopping power, perfect for high-performance driving. Pair them with Rekudo’s brake hoses, made from durable materials to keep your braking system working smoothly under any conditions. If you're looking to tighten up your handling, their sway bars help reduce body roll, giving you better stability in corners. And for a more controlled, comfortable ride, their shock absorbers provide improved damping and smoother handling.
Rekudo parts are designed to fit right in without major modifications, making them a great choice for easy performance upgrades. Whether you're after sharper steering, better braking, or a more planted feel on the road, Rekudo delivers quality you can trust. Check them out at CARiD and take your ride to the next level!
Rekudo® - Disc Brake Calipers
https://www.carid.com/rekudo/disc-brake-calipers.html
Note: Select your vehicle when adding to cart to confirm fitment
Features:
- Designed for high-performance applications
- Made with attention to every detail for consistent performance
- Manufactured from high-grade materials for years of reliability
- Tested to meet or exceed strict industry standards
Rekudo® - Disc Brake Hose
https://www.carid.com/rekudo/disc-brake-hose.html
Features:
Rekudo® - Sway Bar
https://www.carid.com/rekudo/sway-bar.html
Features:
- Reduces body roll & firms up suspension
- Polyurethane frame & end link bushings for durability and performance
- Frame bushings are easily greaseable via included Zerk fittings
- Cold rolled carbon steel construction
- Tubular design to reduce weight
- Utilizes stock mounting points for factory-like fitment
- Durable finish
Rekudo® - Shock Absorber
https://www.carid.com/rekudo/shock-absorber.html
Features:
- Firmer valving for performance
- Single adjustable by hand off-car to increase firmness or compensate for wear
- Utilizes stock mounting points for factory-like fitment, no modification required
- Corrosion resistant paint
- Bushings and most hardware included
- Made in the Netherlands
Now is the perfect time to grab Rekudo suspension, brake, and steering upgrades at a great price! From March 1, 2025, to March 31, 2025, you can save up to 11% on a wide selection of Rekudo products. Whether you’re looking to fine-tune your handling with sway bars, get smoother performance with shock absorbers, or improve braking power with high-quality calipers and hoses, this deal lets you upgrade for less. No promo code needed—prices are already reduced! Don’t miss out—shop now at CARiD before the sale ends!
You can browse the full catalog of Rekudo products at the page below:
Check out other active promotions and coupon codes here:
https://www.carid.com/coupon-codes.html
TheGageinator
Jul 18, 2020 11:28 AM
Gapp
Jan 11, 2007 1:15 AM
