Replacing master cylinder with Delco/Delphi ABS-VI
Old September 5th, 2009 | 3:42 PM
dave99's Avatar
Default Replacing master cylinder with Delco/Delphi ABS-VI
1995 Chevy Lumina car, 3.1 engine, Delco/Delphi ABS-VI Brakes. For master cylinder replacement is there a alternate way to release the spring tension in the abs modulator unit (instead of using a scan tool) prior to removing the entire master cylinder/abs assembly? Is releasing the spring tension required if you are only replacing the master cylinder and not disassembling the entire abs unit?
DOGGM
May 2nd, 2013 11:24 PM
Mille Racer 69
January 19th, 2013 11:04 PM
new2chevy
11
April 25th, 2008 3:20 AM
chevy3quarta
August 6th, 2007 6:34 PM
Quick Reply: Replacing master cylinder with Delco/Delphi ABS-VI
