Silverado Check Engine
Old March 2nd, 2014 | 10:55 PM
Silvy8601's Avatar
Default Silverado Check Engine
I have an 01 Silverado 1500, 4.3 V6 with 116,000 miles. For the past month I've had the check engine light come on when entering the freeway or whenever I depress the gas pedal when traveling at about 70mph. I've checked the code and the 3rd cylinder is misfiring. I have replaced the spark plugs, plug wires, and fuel filter and nothing has changed. I'm at the point of assuming that it is either the fuel pump or fuel injectors, however I am leaning towards the injectors. I'm curious if anyone else has had similar issues or know and understand the issue and how to fix it, thank you!
Old March 3rd, 2014 | 8:15 AM
You didn't say, but did you change the distributor cap and rotor? The distributor cap is a likely trouble spot with 116,000 miles on it and it is cheaper than the injectors. it is worth a try.
Old March 3rd, 2014 | 10:21 AM
namu mac's Avatar
Injector, coil pack, or compression check to see if cylinder is good.
Old March 3rd, 2014 | 7:21 PM
Silvy8601's Avatar
Sorry, yes I replaced the distributor cap and rotor recently. I don't believe it's actually the engine itself because I never have an issue with it until I try and push it hard. That's why I've sort of backed away from doing a compression test. Another question I have is there a way to test the injectors to tell if any of them are bad? Obviously it would be nicer and a lot cheaper to only have to replace a single one instead of the whole spider. And I will definitely explore the coil pack idea. Thanks guys, much appreciated!
AllenC412
April 29th, 2022 1:31 AM
redrotor
Cobalt
August 29th, 2019 8:38 PM
billti
December 12th, 2015 3:18 AM
T'boo Ted
October 28th, 2010 5:15 PM
93chevyman
March 12th, 2010 1:13 PM
Quick Reply: Silverado Check Engine
