spark timing
Old Jun 12, 2011 | 12:36 AM
jamesdoubt@hotmail.com's Avatar
Default spark timing
have a 1979 monte carlo with a 305-has a spreadbore edelbrock intake-a carter afb 600cfm electric choke carb-stock hei with the lightest advance springs-
my question is this-i have read that all gm hei's have 20degrees of machanical timing built into them-but i ran the numbers on the stock distributor,and found this
distributor #1103282
0degrees @1000rpm
10degrees@1700rpm
20degrees@3800rpm
it is factory set at 4degrees BTDC
stock vaccum can has 0degrees@4
20degrees@10
are the canister #'s refering to timing degees at crankshaft or engine vaccum
i am confused because most of the info i have read on timing says that to calculate total machanical timing, you take degrees at crankshaft which would be 4degrees BTDC + 20degrees of machanical advance from distributor-using this my 305 would only have 24degrees of total machanical advance- I would like to have about 32-36degees total machanical-or is this too much timing for a stock 305
jmms
HHR
Apr 17, 2015 4:22 AM
Jkevin
Aug 4, 2013 7:44 AM
Chavynutcase
Uplander
Oct 29, 2012 11:22 AM
Natidonkryda
Jul 29, 2008 3:52 AM
LetsGoMets78
Cobalt
Dec 18, 2006 2:48 PM
