Steering column 94 S-10
I have been having starting issues with my truck. I believe there may be a wiring problem in the steering column.
I removed the steering wheel, turn switch and ignition switch. I need to remove the column cover to see if there is a bad wire.
I can't figure out how to get it off. Its loose and I can move it around, but it will not pull off.
Any suggesstions? I don't want to put it all back together until I figure out what is going on.
Thanks.
Thanks.
taylorisafop
December 19th, 2008 4:57 PM
dmack58
December 29th, 2005 9:28 PM
