TPS low voltage
Old Sep 3, 2017 | 11:48 PM
Zayne Snyder's Avatar
Default TPS low voltage
I have a 2002 Chevy Silverado 1500 with the 5.3. My TPS is reading 2.8 volts as a return signal so I replaced it and it is still reading 2.8v. Anyone have any ideas as to whats causing this? When I bought the truck the PCM fuse was blown went a replaced that and the fuel pump. Also replaced the intake gasket and cam and crank pos sensors. If I remember right the truck used to tack up fine in gear and had plenty of power now it doesn't go about 2-3k rpms in gear.
Old Sep 4, 2017 | 8:56 AM
post the code that is setting.
is the vehicle drive by wire throttle actuator with accelerator position sensor or conventional cable from the accelerator to throttle?
Old Sep 4, 2017 | 12:43 PM
It's not throwing any codes which is weird and its a cable throttle body.
Old Sep 4, 2017 | 3:57 PM
kevinkpk's Avatar
Installed the new one Do you see any voltage change with key on, and moving the throttle? O resistance change with key off, and DVM set to ohm?
Old Sep 6, 2017 | 1:13 AM
do you have a scan tool that can view the tps sensor voltage live?
when you unplug the tps connector
the 5 volt ref should have 5 volts when measured with a voltmeter
the grd should have 0 volts and when a dvom is connected across the 5v and grd wire...you should have 5 volts
depending of the system...the signal wire can have 4.8volts or 0 volts.
check those voltages with the connector unplug and report back
secondly
unplugging the tps connector should set a signal high voltage dtc = open circuit
-jumping the signal to 5 volt power should set a signal low dtc= short dtc
if you get both of those codes, the wiring is good.
