tranny problems in ur 4L60E? found fix!
Old August 12th, 2007 | 3:45 PM
LILSUTHERN's Avatar
Default tranny problems in ur 4L60E? found fix!
MY 97 TAHOE HAS A 4L60E TRANNY IN IT, AFTER DRIVING AWHILE IT STARTS TO SHIFT REALLY HARD TAKING OF FROM REDLIGHTS, IF I STOP AND CUT KEY OFF IT STOPS DOING IT. TRANSMISSION SHOPS ALL TOLD ME $1300.00 - 1800.00 TO REBUILD TRANSMISSION BECAUSE SOLENOIDS ARE GOING BAD....HA! TURNS OUT THAT THEY ARE ALL RIGHT UNDER THE PAN! IF YOU CAN CHANGE THE FILTER YOU CAN REPLACE THEM YOUR SELF FOR AROUND 125.00$$$$ !!!! CALLED A TECKPAC SOLENOID MASTER KIT AND THEY ARE AVAILABLE ONLINE AND EVEN ON EBAY! I HAVE READ HUNDREDS OF COMPLAINTS ONLINE ON THESE FORUMS ABOUT THIS IN TAHOES, SUBURBANS AND SILVERADOS ALL BEGGING FOR HELP AS I WAS AND NO ANSWERS, WELL GUYS WITH A LIL LOOKIN AND ALOT OF RESEARCHIN I KNOW HOW IT'S DONE**WITH TRANNY IN!****HOPE HELPS ANY CHEVY OWNERS, LIL
Old September 13th, 2007 | 2:57 PM
Dave Tyler's Avatar
Default RE: tranny problems in ur 4L60E? found fix!
Wanted you to know that I appreciate your post, I too try to save money and fix my own stuff. I have the 96 Tahoe, not sure if same Tranny but did want to tell you that I liked your post. that is what makes these forums great. Now if you have replaced the dimmer switch, bliker combo?? that is what I need to do. Thanks again. Dave Tyler
donbrearley
June 26th, 2013 10:26 AM
sharkchum
November 2nd, 2012 10:56 PM
abqgolfer
August 27th, 2011 11:30 PM
thejumpsuitman
September 13th, 2010 4:25 PM
a_r_fowler
December 4th, 2007 11:23 AM
Quick Reply: tranny problems in ur 4L60E? found fix!
