Trans clunking under load
Old Nov 23, 2010 | 6:48 PM
TN900r's Avatar
Default Trans clunking under load
Ok....First post. This is the scenario...94 K1500 4x4 5.7 TBI 214,000 mi.
I had vibrations in the tranny during acceleration from first to second and a clunking in OD while pulling a light hill. Replaced tranny (4L60e).
Shifting is super smooth and still have the clunking while accelerating up a slight incline. Can't figure this out. I went and replaced the cap, rotor and button. Same thing. Replaced Ignition coil (original at 214,000 miles figured I'd treat her for only $26). This tranny has no TV cable. It almost acts as though it's trying to shift down to 3rd while pulling a hill but can't make up it's mind.
What's telling the tranny to downshift? I know the ECM tells it, but what tells the ECM to shift down? Is it the throttle position sensor?
Any help would be appreciated. Thanks.
Could this also be a misfire causing the stumble? No codes in the computer either.
Old Nov 29, 2010 | 3:50 PM
Ironhead Dave's Avatar
Is it a dull thump like an internal valve that is shifting back and forth or a sharp knock? With the vibration and the noise, have you checked the flex plate? It may be cracked and vibrating.
Dave
Old Nov 29, 2010 | 8:27 PM
May want to check the motor and transmission mounts also
Old Dec 6, 2010 | 8:26 AM
xkikbxr's Avatar
I had clunking going on while shifting and while going from a stopped position to slow acceleration. The ujoints were bad and the trans mount was wore out. replaced them and everything was good.
dslemaire
Aug 23, 2018 9:46 PM
Travis
Oct 17, 2008 11:58 AM
westboundguy
Aug 6, 2008 9:59 AM
rteas48183
Mar 18, 2008 4:59 PM
harold
Apr 6, 2007 3:20 PM
