truck is dead in the water...HELP PLEASE!!!
so yesterday i changed the steering cloumn in my truck and a bunch of fuses. all was working well last night. today truck was running great, then i noticed with my left signal on, dash lights were flashing again. got home changed a fuse that popped again and now the truck won't start at all. it seems like the starter isn't getting power at all. its an 81 chev c10, anybody know where the starter relay might be? if there is one. i didn;t notice a spot for a fuse for my starter in my fuse box, should there be? i'm guessing not since it worked before. i just put in a brand new starter back in october.
when i'm laying on my floor and turning my key, i can feel the cable or whatever moving on the steering column to activate the starter, but its just not starting. i'm getting adequate power to everything. battery meter goes to normal (for starting when not running, at 1o or 12 volts, whatever it is without the alt running it to 14). my stereo comes on, subs work and all, no issues with that at all.
please, if you have any ideas as to what my issue is, please get back to me asap, as this is my daily driver.
got it all worked out. my neighbor gave me a hand with it and got it working. now i just need to find the short in my driver's side back-up light, and one of my hazard lights ont the passenger side of the box. bulbs are fantastic, but won't come on
i'm not exactly sure what my neighbor had done around my steering column. i know he switched a couple fuses and was checking a lot of things with a tester. and then i had put in a new starter through warrenty.
jggolf
November 30th, 2014 12:17 PM
Fightn17
10
April 8th, 2010 12:45 PM
