Twin tank modification?
Old Jan 14, 2007 | 12:23 AM
10X's Avatar
10X
Default Twin tank modification?
I have a 1985 Chevy Custom Deluxe 10 4X4 with twin fuel tanks. The passenger tank is rusted beyond repair. I want to use the driver’s side tank only. It appears there are 9 lines coming and going from the tank switching unit and 3 lines to each tank.
Does anyone have a picture, drawing or schematic of the lines and which one’s I have to use to accomplish this switch over to the drivers’ tank side only?
Thanks for any suggestions.
10X
Old Jan 14, 2007 | 6:42 PM
golfer's Avatar
Default RE: Twin tank modification?
On my 86 CD C20 with dual tanks I have the same problem with the right side tank. I simply set the switch for the left side tank and that's where it stays.
Old Jan 15, 2007 | 12:22 AM
10X's Avatar
10X
Thanks Golfer, but when I do that I get a slow leak out of the bad tank. I crawled under the truck tonight out in the freezing rain and snow. I cut the flexible lines coming from the good tank and pressurized it. I got fuel out of 1 of the lines and hooked it up to the line going to the pump on the other side of the switching unit. The engine fired and ran for a while until it ran out of gas. By the time I got back home with some gas “24” was just getting ready to start so I will find out tomorrow if everything works.
Thanks for your thoughts.
Old Jan 15, 2007 | 10:45 AM
golfer's Avatar
10X ... not sure what you mean by getting a slow leak out of the bad tank. Do you mean air leak ?
If thats the case it's probably the ball valve ( switching unit )is not fully closing off the bad tank.
Old Jan 15, 2007 | 3:58 PM
10X's Avatar
10X
While the truck sits the fuel will slowly leak out of the bad tank rust holes. Not a terrible lot but enough to make a 2'x2' spot on the driveway. It appears as if it is siphoning from the good tank.
Chuckie52
Sep 15, 2009 8:04 AM
sensei118
Apr 18, 2009 1:04 PM
DarkOne
Oct 13, 2006 11:50 PM
