What engine do I have.
Old Feb 3, 2025 | 6:00 PM
Choptop1's Avatar
Default What engine do I have.
Thank you for the add! A few months ago I purchased a 2016 Special Construction Trike w/a Chevy 5.7 small block, from the original owner. He new less than nothing about it and the builder
2016 350/350/9
2016 350/350/9"
is playing hard to contact. It is said to be a crate engine from Summit Racing, it has 2,000 miles on it. Their are no numbers on the front at all, I have the water pump and alternator off. The casting number 14088548 indicates it is a '86 - 88 but other sites say '86 - '94, truck 2 or 4 bolt mains ? On the drivers side, just before the tranny, their are some numbers" GM 5.7 L G ", then across from that is "1 CFD " and below all those is 312993 and below the headers is a small plaque that says Serial number and it is the same 312993. On the head their are some numbers " 10110810 " next to it is a " FO15 " , also a what looks like a clock with with the pointer pointing to 11 and then a separate mark below what would be 6 on the clock. On the passenger side, under the header is "CFD w/548 under it. It is a carbureted engine. It may have been decked and that may have erased the numbers on the front pad. It would just be nice to know what I have, maybe the Horsepower, I am thinking around 190 hp which would be plenty for a 1,300 lb bike. Thanks in advance.
Chebby Bill
Dec 12, 2022 7:11 AM
Zachary1748
Mar 28, 2014 12:50 AM
motox-010
Sep 28, 2009 10:37 AM
atl530i
Camaro
Nov 7, 2006 12:47 AM
