Antifreeze
Antifreeze
Does everyone use Dex Cool? If not, what do you use? How do you feel about companies that claim that their antifreeze can be used on any make, model or color of antifreeze?
Honestly I don't see a reason not to use dexcool. My personal opinion is use what it came with/what the manual says. Dexcool is pretty readily available anymore so theres really no reason to use anything else.
If its a severe budget problem or some kind of emergency I have used "universal" coolants for top offs but I also usually recommend flushing it out and putting the recommended stuff back in when its possible.
use dexcool. its designed for the system.
I have seen organic acid coolants react when different types are mixed. Chrysler has warning regarding there oat coolant and new hoat coolant. if mixed, they will gel.
This is the extreme worst case scenario.
get the right stuff and don't mix it will anything else. How often do you change the stuff....once every 5 years.
